how to create directories in belege transfer
10
letzte Antwort am 27.03.2024 14:36:52 von Venkata
BOGMYAMINI
Nachricht 1 von 11
294 Mal angesehen
Nachricht 2 von 11
285 Mal angesehen
Do you use version 5.33? There's an issue at the moment: Frage zu Neue Version DATEV Belegtransfer V. 5.33 So please update to version 5.34 when it's available in near future.
Nachricht 3 von 11
282 Mal angesehen
DATEV Belegtransfer - Verzeichnisse hinzufügen - DATEV Hilfe-Center
Automated translation:
2 Procedure
To be able to work with DATEV document transfer, one or more directories must be added to the program. The documents are uploaded from the directories to DATEV Belege online. The directory in DATEV Document Transfer corresponds to the document types in DATEV Unternehmen online, so only a directory that was previously created as a document type in DATEV Unternehmen online can be added.
Add directories
Prerequisite:
The DATEV document transfer program is installed.
Procedure:
1. Start DATEV document transfer.
2. Log in with the access medium (DATEV SmartCard, DATEV SmartLogin, DATEV mIDentity).
3. Close the browser.
4. In DATEV document transfer, click on Create directories for documents online.
5. In the Create directories for documents online window, make the settings for the base directory.
6. Click on Save.
7. Select the companies for which you want to create directories.
Note
Select companies
The companies for which no directories have yet been created in DATEV document transfer are displayed. Uncheck Show only companies for which no directories have yet been created if you want to add a new directory for a company that already exists in DATEV Document Transfer.
8. Click on Next.
9. Check the desired document type.
10. Click on Create directories.
When the company is displayed on the start page in DATEV document transfer, the new directories have been created.
siro
Nachricht 4 von 11
267 Mal angesehen
So you and @Venkata are trying to solve Fabian Gatermann problem?
Venkata
Nachricht 5 von 11
245 Mal angesehen
Hi Siro,
Not really. I am trying to understand how to resole the issue of creating base directories.
How and where to create base directories for the company?
How to make settings for the base directory?
Are there any prerequisites to create base directory?
We are unable to move to next page from here.
refer the attachment.
BOGMYAMINI
Nachricht 6 von 11
216 Mal angesehen
 i tried by using the steps mentioned .i am still facing the same issue. Refer the Attachment
Nachricht 7 von 11
193 Mal angesehen
It is really puzzling that two different users are using the exact same photos for the the exact same problem.
Are you using two different accounts here?
siro
Nachricht 8 von 11
160 Mal angesehen
change "handling uploaded documents"
from ...\documents\belegetransfer\archive
to ...\documents\belegearchive
siro
Nachricht 9 von 11
72 Mal angesehen
@BOGMYAMINI did it work?
Venkata
Nachricht 10 von 11
38 Mal angesehen
Yes, It did work.
Venkata
Nachricht 11 von 11
34 Mal angesehen
we are from the same firm and getting same issue. It got duplicated
10
