Vorlagenverwaltung ausfüllbares PDF
letzte Antwort am 04.03.2025 12:41:55 von einmalnoch
SW2024
169 Mal angesehen
Guten Tag,
ist es mittlerweile möglich ausfüllbare PDFs erstellt z.B. mit Tungsten (Kofax) in die Vorlagenverwaltung zu bekommen?
Ich habe versucht das PDF rüber in die VV zu ziehen und dann wird mir angezeigt: Datei kann nicht importiert werden.
Irgendwie muss dieser technische Fortschritt doch mit der VV kombinierbar sein oder?
Thread zu Office Management verschoben durch @Hannes_Muschiol
159 Mal angesehen
Hello SW2024,
It sounds like you're trying to import a fillable PDF (created with Tungsten or Kofax) into a template management system but encountering an issue where it says, "File cannot be imported." The problem you're facing might be related to compatibility between the fillable PDF format and the VV system's template management capabilities.
Here are a few things to consider and try:
  1. PDF Compatibility: Some systems might not support interactive PDFs (those with fillable forms) directly, especially if the template management system is expecting a specific file type or format. Try checking the file type and ensuring it's a standard PDF that doesn't rely on complex interactive elements.
  2. Flatten the PDF: If the system struggles with fillable PDFs, one option is to flatten the PDF. This means removing any interactive fields so that it's treated as a simple, static document. You can do this by printing the form to PDF (which removes the interactivity) or using a PDF editor to flatten it.
  3. Check File Size/Specifications: Ensure the file isn't too large or doesn't exceed any limits imposed by the template management system.
  4. VV Compatibility Settings: Review the settings or documentation for your VV (presumably, the template management platform). There may be certain settings or plugins needed to support interactive PDFs or other complex formats.
  5. Support: If these options don't work, contacting the support team for either Tungsten (Kofax) or the VV platform could help. They might have more detailed guidance or be able to provide an update or patch that resolves the compatibility issue.
Let me know if you need more help or clarification on any of these steps!
Best regards
143 Mal angesehen
@SW2024
Auch vor fünf Jahren war dieser Wunsch schon alt
https://www.datev-community.de/t5/Office-Management/DMS-neu-Word-Formulare-als-ausf%C3%BCllbare-PDF-per-Mail-versenden/m-p/153995/highlight/true#M10344
Der Link auf die alte Newsgroup ist nicht mehr gültig.
Da es in DATEV technisch nicht gewollt ist wird es in den nächsten 10 Jahren auch im Rechenzentrum nichts werden.
@Gelöschter Nutzer
Auch wenn Sie schön auf Englisch schreiben, DATEV erzählt viel und die Vorlagenverwaltung ist schlicht EDV-technische Frühsteinzeit und kann ausschließlich mit Microsoft Datenformaten umgehen.
