Is there a Datev user guide in english?
letzte Antwort am 16.10.2017 16:52:04 von
larsp
2199 Mal angesehen
Looking for a user guide in English, ideally or online or perhaps as an old fashioned manual?
1295 Mal angesehen
Dok.-Nr. 1036092
Unterstützungsangebote: Übersetzungshilfen zur Steuerdeklaration und
Auswertungen in englischer Sprache
agmü
1295 Mal angesehen
Could you secify your inquiry, please. What kind of user guide you are looking for?
So far as I'm famliar with the various DATEV Programms al user guides should they exist at all, are in german only.
Otherwise you might search inside LEXinfom  database; available either via https://www.datev.de/dnlexom/client/app/index.html or via the searchbar in the right upper corner of the "Arbeitsplatz".
Andreas G. Müller
1295 Mal angesehen
If you have found "a user guide for DATEV" as an "old fashioned manual" in english, could you please look for the same one in german for me? THX
1295 Mal angesehen
You can translate all documents from http://www.datev.de/info-db using this engine, just copy and paste the text:
https://www.deepl.com/translator
Regards
Christian Deuerlein
