DATEV "Kanzlei und Rechnungswesen"
19
letzte Antwort am 28.10.2018 17:42:21 von andreashofmeister
norther73
Nachricht 1 von 20
2053 Mal angesehen
Hello everybody
Need help. I tried to install DATEV "Kanzlei und Rechnungswesen" but got an error. Then I tried to install Zahlungsverkehr separately but got the same error about Datev Platform.
But, for example, "Lohn und Gehalt" is installed without any errors
Any suggestions? What and where to do?
Nachricht 2 von 20
1262 Mal angesehen
What do you want? You'll try to install another DATEV PC-Client? Or ...?
If it's a completely new install, you have to go via "Installation starten". There you can select "Neuinstallation" and select all programs, you want to install. DATEV then installs all selected programs in correct order because some programs depend on other programs (i.e. DATEV Kanzlei Rechnungswesen needs DATEV Arbeitsplatz first and Zahlungsverkehr needs DATEV Rechnungswesen).
norther73
Nachricht 3 von 20
1262 Mal angesehen
It's WTS with Datev Client and completely new install
I did through "Installation starten", then I can select typical or custom installation (as I remember), then select programs...or I'm a stupid admin
So I will try your way in the evening...
Nachricht 4 von 20
1262 Mal angesehen
That's correct. But if it's a new install you have to check the box "Neuinstallation". Otherwise DATEV wont install anything.
mkinzler
Nachricht 5 von 20
1262 Mal angesehen
What does the logfile tells you?
norther73
Nachricht 6 von 20
1262 Mal angesehen
So I go your way. But I didn't find the checkbox "Neuinstallation", I have only "Typical (recommended option)" and "Custom" installations. And I installed applications only via Installations-Manager 4.52
"Zahlungsverkehr needs DATEV Rechnungswesen" - both of them have cross-links to each other.
And here it is - the same error.
Also Zahlungsverkehr can not be installed because of...Zahlungsverkehr.
norther73
Nachricht 7 von 20
1262 Mal angesehen
norther73
Nachricht 8 von 20
1262 Mal angesehen
So what am i doing wrong?
Nachricht 9 von 20
1262 Mal angesehen
No, that's the wrong window. You don't have to install all programs manually by rightclicking on it.
Take this way:
Klick, next.
Activate checkbox Neuinstallation and choose all programs which you want to install.
Then DATEV puts all programs to install automatically in the right install order.
Nachricht 10 von 20
1262 Mal angesehen
Try to run the "Servicetool" and perhaps check the red lamps.
There could be many reasons for this fault:
http://www.datev.de/dnlexom/client/app/index.html#/search
norther73
Nachricht 11 von 20
1262 Mal angesehen
Hi all
Another attempt to install DATEV:
1. I did deinstallation of Datev from DatevWTS via deinstnacharbeitentool.exe and rebooted the server
2. I did installation of Datev-Platform from DVD using default (recommended) settings and rebooted the server
3. I can't proceed with install of Datev-Programs because the installation source pull-down list is empty. What I missed? What's wrong?
Nachricht 12 von 20
1262 Mal angesehen
Is network drive L: connected?
mkinzler
Nachricht 13 von 20
1262 Mal angesehen
Try to repair "Daten-Manager" (B0000022).
norther73
Nachricht 14 von 20
1262 Mal angesehen
Yep, network drive L: is connected
norther73
Nachricht 15 von 20
1262 Mal angesehen
OK, I will try...
Nachricht 16 von 20
1262 Mal angesehen
Otherwise, it's easier if you contact a DATEV Systempartner to find a solution via teamviewer or other remote support tools.
norther73
Nachricht 17 von 20
1262 Mal angesehen
Is there a registry key or smth else by which the Datev Installer can check if there is the first-time installation or not?
Nachricht 18 von 20
1262 Mal angesehen
If you clean the registry completely by searching after DATEV and DATEVeG. There are 2 main keys: HKLM and HKCU > software.
norther73
Nachricht 19 von 20
1262 Mal angesehen
Hi All
Thanks a lot for your appropriate help. The topic question was successfully resolved. The main cause of errors was faulty hardware key (SWM). After SWM replacement the Datev installation was like a piece of cake
Nachricht 20 von 20
1262 Mal angesehen
Thanks for your feedback!
Never mind...
