Fehler #INI07253 bei Installation von Basisdienste Office SR 8.02
letzte Antwort am 10.09.2017 15:54:46 von lulu99
lulu99
1902 Mal angesehen
Einen schönen Sonntag.
Per Download wurde das Update Basisdienste Office SR 8.02 bereitgestellt. Bei der Installation kommt folgender Fehler:
INI07253 Selbstregistrierung von Assemblies gescheitert
Eine Deinstallation und Neuinstallation brachte auch keinen Erfolg. Gleiches Problem wieder.
Weiß jemand Rat?
Vielen Dank und viele Grüße Kai Klintworth
Auszug aus dem LOG:
#T:13:43:02,618 <INF> #L:Directory deleted: 'C:\DATEV\DATEN\Install\GAC\K0000133\8.0.56\MyGacProg'
#T:13:43:02,619 <INF> #L:Directory not found 'C:\DATEV\DATEN\Install\GAC\K0000133\8.0.56\MyGacProg'
#T:13:43:02,620 <INF> #L:File deleted: 'C:\DATEV\DATEN\Install\GAC\K0000133\8.0.56\SO9CLI\cli_basetypes.dll'
#T:13:43:02,621 <INF> #L:File deleted: 'C:\DATEV\DATEN\Install\GAC\K0000133\8.0.56\SO9CLI\cli_cppuhelper.dll'
#T:13:43:02,622 <INF> #L:File deleted: 'C:\DATEV\DATEN\Install\GAC\K0000133\8.0.56\SO9CLI\cli_oootypes.dll'
#T:13:43:02,623 <INF> #L:File deleted: 'C:\DATEV\DATEN\Install\GAC\K0000133\8.0.56\SO9CLI\cli_ure.dll'
#T:13:43:02,624 <INF> #L:File deleted: 'C:\DATEV\DATEN\Install\GAC\K0000133\8.0.56\SO9CLI\cli_uretypes.dll'
#T:13:43:02,626 <INF> #L:Directory deleted: 'C:\DATEV\DATEN\Install\GAC\K0000133\8.0.56\SO9CLI'
#T:13:43:02,626 <INF> #L:Directory not found 'C:\DATEV\DATEN\Install\GAC\K0000133\8.0.56\SO9CLI'
#T:13:43:02,627 <INF> #L:Directory deleted: 'C:\DATEV\DATEN\Install\GAC\K0000133\8.0.56'
#T:13:43:02,628 <INF> #L:Directory not found 'C:\DATEV\DATEN\Install\GAC\K0000133\8.0.56'
#T:13:43:02,629 <INF> #L:Directory deleted: 'C:\DATEV\DATEN\Install\GAC\K0000133'
#T:13:43:02,629 <INF> #L:Directory not found 'C:\DATEV\DATEN\Install\GAC\K0000133'
#T:13:43:02,630 <INF> #L:Directory deleted: 'C:\DATEV\DATEN\Install\GAC'
#T:13:43:02,630 <INF> #L:Recursive delete done: 'C:\DATEV\DATEN\Install\GAC'
#T:13:43:02,630 <INF> #L:</Delete>
#T:13:43:02,630 <INF> #L:</Install>
#T:13:43:02,633 <INF> #L:</Install>
#T:13:43:02,633 <EXC> #L:Selbstregistrierung konnte nicht durchgeführt werden.
Type: InstallerException
Message: Selbstregistrierung konnte nicht durchgeführt werden.
Source:
Datev.Installation.Installer.Business
StackTrace:
   bei Datev.Installation.Installer.Business.Utilities.SelfRegistrationManager.ProcessSelfRegistration(Collection`1 selfRegList)
   bei Datev.Installation.Installer.Business.Worker.FileCopyInstructionExecutor.ProcessSelfRegistrationList(Collection`1 selfRegList)
   bei Datev.Installation.Installer.Business.Worker.FileCopyInstructionExecutor.DoExecuteStandard(FileCopyInstruction fileCopyInstruction)
   bei Datev.Installation.Installer.Business.Worker.FileCopyInstructionExecutor.ExecuteImpl(InstallInstructionBase instruction)
   bei Datev.Installation.Installer.Business.Worker.InstallInstructionExecutorBase.Execute(InstallInstructionBase instruction)
   bei Datev.Installation.Installer.Business.Worker.InstallComponentProcessor.InstallImpl(IInstallerJobItem jobItem)
   bei Datev.Installation.Installer.Business.Worker.InstallJobItemProcessorBase.Install(IInstallerJobItem jobItem, Boolean setInstallState)
   bei Datev.Installation.Installer.Business.Worker.InstallPackageProcessor.InstallImpl(IInstallerJobItem jobItem)
   bei Datev.Installation.Installer.Business.Workflow.InstallerJobStepExecuterPerformer.Install(IInstallerJobItem jobItem, Boolean setInstallState)
   bei Datev.Installation.Installer.Business.Workflow.InstallerJobStepExecuterPerformer.PerformInstallJobs(ICollection`1 jobItems)
InnerException:
Datev.Installation.Installer.CommonData.Exceptions.InstallerException: Selbstregistrierung konnte nicht durchgeführt werden.
#T:13:43:02,637 <INF> #L:</Installing TopLevelProduct>
#T:13:43:02,638 <INF> #L:</Performing>
#T:13:43:02,650 <INF> #L:MessageDialog: Show modal message INI07253 Selbstregistrierung von Assemblies gescheitert
#T:13:43:02,650 <INF> #L:MessageDialog: Message text: Selbstregistrierung konnte nicht durchgeführt werden.
lulu99
598 Mal angesehen
Problem erstmal gelöst. Datev Programm-DVD 11.0 war noch nicht installiert. Daher war auch noch nicht Version 8.0 aufgespielt. Nach Deinstallation und Installation von der Version 7.3 von der vorigen DATEV-DVD 10.1 läuft es nun wieder.
