Kanzlei-Rechnungswesen installation
letzte Antwort am 16.04.2024 20:11:35 von Venkata
Venkata
653 Mal angesehen
Hello,
I have installed DATEV Mittellstand Faktura V/14 with the below downloads.
DATEV Mittelstand Faktura 2024 V. 12.4 (Haupt-Release) &
DATEV Mittelstand 2024 - Service-Release für V. 12.4)
How ever the Arbeitsplatz is not showing Kanzlei-Rechnungswesen module.?
Do I need to install any other download? If ,Yes, can you share the link?
Vilen Dank
646 Mal angesehen
Nope, because in DATEV Mittelstand Faktura, there is no Rechnungswesen and especially no Kanzlei-Rechnungswesen.
It depends on your licence at DATEV. "Normal" companies don't get Kanzlei-Rechnungswesen without talking to DATEV.
So if you want to do your account but without the annual financial statements (Jahresabschluss), you have to use this ISO: DATEV Datenträger-Download-Portal Login with SmartCard / SmartLogin required if you have the non-compact version.
DATEV. Very complicated.
Venkata
639 Mal angesehen
Thanks for the update.
I have the Smart login (Unternehmen online) Out of the below, which one is Kanzlei Rechnungwesen?
understand, it is complicated , when you do first time for sure 🙂
Vilen Dank
635 Mal angesehen
No one, because your SmartLogin says: you are a company, not a tax consultant. Do you have a licence for DATEV Kanzlei Rechnungswesen?
You can check that now in your installed DATEV. Go to search > Service Anwendungen > Hard- und Software. If there is no DATEV Kanzlei Rechnungswesen (instaed of Mittelstand) listed, you have to talk to your tax consultant. He can buy the right software for you.
Venkata
603 Mal angesehen
Thank you. I really appreciate your quick responses.
I have one more issue: I could see Mittelstand Faktura mit Rechnungswesen compact
and
Mittelstand Fakture
But I could not find the link for  "Mittelstand Faktura mit Rechnungswesen Professional download?
Where do I downlowd  ""Mittelstand Faktura mit Rechnungswesen Professional"
Unfortunately our Tax lawyer who ordered this also do not know this as he has done this 10 years before.
Appreciate this help.
With best regards
Venkata
Venkata
602 Mal angesehen
Thanks.
I consulted my Tax lawyer and he confirmed that we dont need Kanzlei Rechnungswesen.
But we need "Mittelstand Faktura mit Rechnungswesen Professional version" to be installed.
I am able to find the below
But not ""Mittelstand Faktura mit Rechnungswesen Professional version"
almost a week we are struggling to resolve...
Some who DATEV is not that simple.
with best regards
Venkata
594 Mal angesehen
There is no version called like that. Then you have to use the ISOs from your post #3. It may help, if you open the installationsmanager and search there for Rechnungswesen or Mittelstand Faktura mit Rechnungswesen.
Remote support via teamviewer would be much easier 😋.
Venkata
588 Mal angesehen
Thank you for your prompt response. Really appreciate it 🙏
As we doing this first time and unable to progress for last 10 days.
Would you mind to come for quick session on Team viewer. I can share google invite or WhatsApp call if that helps.
today understand it is late. May be tomorrow morning
with best regards
Venkata
