IONOS AI Model Hub vs. personenbezogene Daten
0
dstoll
Nachricht 1 von 1
1561 Mal angesehen
Eher zufällig bin ich eben über das Angebot "AI Model Hub" von IONOS gestolpert. Die bieten API Zugriff auf Open Source KI Modelle und geben an, vollständig DSGVO konform zu sein (RZ in Deutschland bzw. Europa, übergebene Daten werden niemals zu Trainingszwecken verwendet, kein Zugriff "durch Dritte", etc.).
Stateless Service: AI Model Hub operates as a stateless service, discarding user prompts and outputs at the end of each session. Each session stands alone, and your interactions remain private, free from logging, recording, or reuse for model training.
Wie würdet ihr das einschätzen, was "vollständig DSGVO konform" bedeutet? Kann man da personenbezogene Daten übergeben und vom KI Modell verarbeiten lassen?
Dazu schreiben Sie zB:
For High-Risk Systems
If your application's use case falls into a high-risk category, such as employment, credit, or education, you have significant obligations. The AI Model Hub provides the flexible infrastructure to help you achieve the following:
    Data Governance: Our managed vector database services give you full control over the data you use for RAG. You remain responsible for the quality, relevance, and bias-checking of your data; our platform ensures it is stored and processed securely within our German data centers.
    Logging and Traceability: The AI Act requires that high-risk systems maintain event logs. While IONOS Cloud does not provide a pre-configured AI Act logging template, our API-first platform allows you to log all API requests and responses using your own logging solutions to build a compliant audit trail.
    Human Oversight: High-risk systems must be designed for effective human oversight. Our APIs serve as flexible building blocks, allowing you to design and implement your own "human-in-the-loop" workflows, such as routing an AI-generated output for human approval within your application logic.
Wenn ich die Vektordatenbanken für RAG nicht nutzen würde (erster Punkt, ist vielleicht nochmal ein ganz anderes Thema), steht da ja "nur", dass ich für die Protokollierung von Anfragen selbst verantwortlich bin und Ergebnisse der Anfragen mittels "human-in-the-loop" selbst prüfen müsste.
0
